PROBLEM
Option for 'Using a Template' to create web apps is missing from ArcGIS Online
First Published: August 13, 2018
When attempting to create a web application, the 'Using a Template' option is missing from ArcGIS Online.
An image showing the 'Using a Template' option missing from ArcGIS Online.
Cause
This issue occurs when the organization changes the configurable apps group to a custom group that does not contain the Esri Default configurable apps in the organization settings page. This setting controls the accessiblity of configurable apps by users within the organization.
An image of the Configurable Apps section in the Settings page.
Solution or Workaround
To enable the Using a Template option for creating a web application, click the Organization tab > Settings > Map. Under the Configurable Apps section, select Esri Default, and click Save at the top-left corner of the page.
User-added image
The Using a Template option now appears in the Create drop-down list.
An image showing the 'Using a Template' option in the Create drop-down list.
Article ID: 000018656
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
