ERROR
Service failed to start. System.CachingTools.GPServer: undefined
Last Published: April 10, 2025
Error Message
When trying to start the CachingTools system service in ArcGIS Server Manager, the following error may be encountered:
Screenshot of Server Manager that displays the error you get when trying to start CachingTools. This is the error: Service failed to start. System.CachingTools.GPServer: undefined
Upon checking the Server Manager logs, we see this error has greater detail:
"Failed to construct instance of service 'System/CachingTools.GPServer'. The toolbox did not load: C:\Program Files\ArcGIS\Server\ArcToolBox\Services\Caching Tools.tbx"
Cause
The toolbox path in Server Admin > services > System > CachingTools leads to the old location of the service toolbox file that used to be at "${AGSSERVER}/ArcToolBox/Services/Caching Tools.tbx" in 11.0 and earlier.
Starting with version 11.1, the path was changed to "${AGSSERVER}/framework/runtime/ArcGIS/Resources/ArcToolBox/Services/Caching Tools.tbx" and in 11.2, the ArcToolbox folder was removed from the server installation directory.
It is unknown why some 11.2 and later deployments are still pointing to the old path, but one theory is that an improper upgrade was performed, though there is nothing to back this up.
Solution or Workaround
This workflow only applies to ArcGIS Enterprise deployments, version 11.1 and later.
Change the toolbox path of CachingTools so it matches the one of the toolbox file that corresponds to it inside the ArcGIS Server installation directory.
  1. Log in Server Admin and navigate to services > System > CachingTools.
  2. Under the Properties section, note the toolbox property with the value: ${AGSSERVER}/ArcToolBox/Services/Caching Tools.tbx
  3. At the bottom of the page, select edit.
  4. Look for the toolbox property and change its value to:
  1. Save the edits, and go back to Server Manager and start the CachingTools service again.
Article ID: 000034003
Software:
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
