ERROR
The tool is not licensed
First Published: May 5, 2016
Last Published: January 26, 2022
Error Message
While attempting to create a globe cache in ArcCatalog for an ArcGIS Server globe service, the following error message is returned:
"The tool is not licensed".
This article applies to retired ArcGIS versions 9.x and 10.0. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Cause
To create a globe cache successfully, the 3D Analyst extension is required for ArcGIS Desktop. The extension must be licensed, and also enabled in ArcCatalog.
Solution or Workaround
If there is no 3D Analyst extension available, check with the License Manager administrator to make sure the 3D Analyst extension is licensed.
  1. In ArcCatalog navigate to Tools > Extensions and ensure that 3D Analyst is checked.
  2. Re-run the globe cache tool.
Article ID: 000009617
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
