ERROR
During the ArcIMS 4.0.1 Post Installation, after entering the Web site and Output directory location, the following error message occurs:
"The system cannot find the file specified. C:\documents and settings\username\aimsdefaults.properties"
The file aimsdefaults.properties located in the default location c:\program files\arcgis\arcims\common has been edited and was saved incorrectly with the wrong extension, e.g. aimsdefaults.properties.txt.
The error message is misleading, as the setup simply cannot copy the original file to the mentioned target location.
Code:
# ArcIMS v4.0.1 Site Properties Settings
#UserName - Login for the ArcIMS Administrator
#HostName - Full name of the host machine. The full name of the host machine may mean
# including the domain name. For UNIX users, you will need to include the domain name.
#HostALIAS - Alias of the host machine
#HostURL - URL of the host machine
#WorkingDir - Default working directory, where map configuration files are stored
#WebSiteDir - Default web site directory, where created sites are stored
#ImagePath - Path to the image output directory
#ImageURL - URL for image output (Using HostURL)
#Scavenger - Scavenger cleanup interval in minutes
#IndexBuilderEXE - Path of the geocoding index builder (aimsindxb.exe)
#WebBrowser - Location of default web browser (required for OnLine Help)
#WebBrowser.usesQuotes - Netscape 6 users must switch this value to true
#ArcIMSHelp - Main HTML page for ArcIMS OnLine Help
#ImageMemory - Amount of memory to reserve for Spatial Server images
#MaxImageMemory - Maximum Image memory Limit allowed in Megabytes
#ForceAddServers - Upon launching of ArcIMS Manager, if "true", a default server is added
# to each monitors with no servers associated with it; if "false", no servers are added
ImageURL=http\://ARCIMSHOST/output
ImagePath=C\:/arcIMS/output
HostName=ARCIMSHOST
HostALIAS=ARCIMSHOST
HostURL=http\://ARCIMSHOST
Scavenger=10
UserName=admin
WebSiteDir=c\:/ArcIMS/Website
WorkingDir=c:\:/ArcIMS/AXL
IndexBuilderEXE=C\:\\Program Files\\ArcGIS\\ArcIMS\\IndexBuilder\\aimsindxb.exe
WebBrowser=C\:/Program Files/Plus!/Microsoft Internet/iexplore
WebBrowser.usesQuotes=false
ArcIMSHelp=C\:/Program Files/ArcGIS/ArcIMS/Manager/Help/arcims_help.htm
ImageMemory=4
MaxImageMemory=250
ForceAddServers=false
Article ID:000006390
Get help from ArcGIS experts
Download the Esri Support App
