BUG
The Summary Reports tool cannot be run in ModelBuilder without first manually creating an output folder
Last Published: January 9, 2026
When using the Summary Reports tool in a model, the output parameter cannot be set, preventing the model from being run.
Cause
This is because the model requires an existing folder before the output parameter can be set.
User-added image
Workaround
Manually create a folder in the default projects location. Then point to this folder when setting up the model.
Article ID: 000017577
Software:
  • ArcGIS Business Analyst Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
