PROBLEM
The Spline with Barriers script fails to execute
First Published: May 5, 2016
When running the script, Spline with Barriers, a message is returned indicating there was a failure to execute and that Java is not installed. An example of the error returned is below.
[O-Image]
Cause
This tool requires the Java Runtime Environment Version 5.0, or higher, to be installed.
Solution or Workaround
Download and install the latest free version of the Java Runtime Environment using the link below.
Java.com
Another option is to open the Desktop Help for this script. There is a link to download the Java Runtime Environment in the first bullet of the Usage Tips.
    Article ID: 000009560
    Software:
    • ArcMap
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
