ERROR
When using Operations Dashboard for ArcGIS and attempting to connect to a portal using a proxy, the following error is returned:
"The remote server returned an error: (407) Proxy Authentication Required."
By default, Operations Dashboard proxy authentication is turned off. It can be enabled through the config file.
C:\Users\<user>\AppData\Local\Apps\2.0\6DQR2MG2.BTG\XDACJNYJ.970\oper...app_f464941b06bea132_000a.0002_192664b3a1b966dc
Code:
<system.net>
<defaultProxy enabled="true" useDefaultCredentials="true" >
<proxy autoDetect="true" usesystemdefault="True"/>
</defaultProxy>
Article ID:000012718
Get help from ArcGIS experts
Download the Esri Support App
