ERROR
The portal is unable to establish a connection for the Living Atlas update
Last Published: December 15, 2025
Error Message
While updating the content of ArcGIS Living Atlas of the World in Portal for ArcGIS, the following error message is returned.
Error: The portal is unable to establish a connection for the Living Atlas update. Please check your portal administrator logs and try again later
Cause
This usually happens due to network connectivity issues or proxy/firewall restrictions.
Solution or Workaround
  1. Check Internet Access - Ensure the portal machine has internet access and try accessing https://www.arcgis.com and https://livingatlas.arcgis.com from a browser on the portal server machine.
  2. Verify Proxy Configuration - If your organization uses a proxy, make sure it's configured in the Portal Admin Directory or add the proxy settings if missing.
  3. Firewall and 'Allow' listing - Ensure the following domains are not blocked by your firewall. If not, ask your network/security team to include these for allowable outgoing HTTPS connections:
    • *.arcgis.com
    • *.esri.com
    • livingatlas.arcgis.com
  4. Update the Security Configuration (portaladmin/security/config) to also include the following property: "allowedProxyHosts":"(.*).arcgis.com,(.*).esri.com,livingatlas.arcgis.com"
  5. Retry the update
Article ID: 000036774
Software:
  • Portal for ArcGIS
  • ArcGIS Living Atlas
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
