BUG
The Parcel Editor's Regenerate command applies incorrect bearings to the radial lines of curves that have a central angle greater than 180 degrees.
These incorrect bearings can only occur if the initial release of ArcGIS 10.2.2 for Desktop Parcel Fabric General Maintenance Patch, dated 10-01-2014, has been installed. These incorrect values are written only if the Regenerate command is then run on parcels with curves greater than 180 degrees.
Article ID: 000012219
Get help from ArcGIS experts
Download the Esri Support App
