ERROR
The modified geometry must be a different geometry instance from the feature's original geometry (e.g., a copy or new instance)
Error Message
A coding practice has been identified that could lead to geometric network inconsistencies, and the following errors may be displayed as a result of guards against this coding practice that have been installed in ArcMap.
"The modified geometry must be a different geometry instance from the feature's original geometry (e.g., a copy or new instance)"
"The feature is mutually exclusive. Cannot update shape."
The following is a summary of the coding practice: Getting the geometry of a feature through the IFeature.Shape property, updating the reference to the feature, and using that same reference to set the geometry to the feature, may cause geometric network inconsistencies.
ArcMap is in Mature support and will be retired March 1, 2026. There are no plans for future releases of ArcMap, and it is recommended that you migrate to ArcGIS Pro. See Migrate from ArcMap to ArcGIS Pro for more information.
Cause
The error is due to a fix that was made to guard against a coding practice, which could lead to geometric network inconsistencies.
Solution or Workaround
Support for Visual Basic for Applications (VBA) for ArcMap and ArcCatalog ended with the ArcGIS 10.2.2 release, and Esri has not included VBA compatibility setups since version 10.5. See: ArcGIS Desktop and VBA Moving Forward
If the error is being raised through one of the core ArcGIS tools or commands with no custom code, contact Esri Technical Support so that a new incident can be created and the problem reproduced.
If the error is being raised through the use of custom code, modify a copy of the geometry instead of the geometry itself. This can be done through the use of IFeature.ShapeCopy instead of IFeature.Shape, so that a copy of the feature’s shape is modified.
The code example listed below shows the changes necessary to circumvent the error message.
The correct coding practice of using IFeature.ShapeCopy is being used, while the line that may cause the error to appear has been commented out.
pEditor.StartOperation
Set pEdLayers = pEditor
Set pFeatures = pEditor.EditSelection
pFeatures.Reset
Set pFeature = pFeatures.Next
Dim pGeom As IGeometry
'This line is incorrect
'Set pGeom = pFeature.Shape
'This is the correct way to access the geometry for modification
Set pGeom = pFeature.ShapeCopy
Dim pGeomColl As IGeometryCollection
Set pGeomColl = pGeom
Dim pPointColl As IPointCollection
Set pPointColl = pGeomColl
Dim pPoint1 As IPoint
Dim pPoint2 As IPoint
Set pPoint1 = Create_PointGeometry(-5959.167882, 5667307.034188)
Set pPoint2 = Create_PointGeometry(-5983.323227, 5667300.739636)
pPointColl.AddPoint pPoint1
pPointColl.AddPoint pPoint2
Set pFeature.Shape = pGeom
pFeature.Store
pEditor.StopOperation ("Update geometry of edge feature")
Article ID: 000010000
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
