ERROR
The map was successfully published, however the service did not start automatically
First Published: May 5, 2016
Error Message
Attempting to start a map service with Web Feature Services (WFS) enabled fails with the following error:
"The map was successfully published, however the service did not start automatically."
Cause
WFS cannot be enabled on map services with joined (virtual) attributes. If publishing from ArcMap, the Analyze function catches this error before it is published as a WFS. However, enabling WFS on an existing map service results in an error because of the limitation of using joins on a service with feature access.
This error is also generated when one of the map service layers has multiple ObjectID fields. This can occur when saving joined attributes, including the joined ObjectID, to a new feature class.
Solution or Workaround
Create a new feature class containing the joined attributes. If there are duplicate ObjectID fields, remove or turn off the field.
    Article ID: 000011881
    Software:
    • ArcGIS Server
    Get support with AI
    Start chatting now
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
