ERROR
The level of configured provisioned throughput for the table was exceeded
First Published: December 15, 2022
Last Published: December 15, 2022
Error Message
Making multiple requests to hosted feature layers in ArcGIS Enterprise over a short period of time results in progressively slower performance when rendering the layers in a map.
Inspecting the ArcGIS Server logs, the following severe errors can be seen:
  • Exception in setting 'ownership' role Initialization of the site failed.Unable to retrieve 'Permissions' resource information. Configuration store error. AWS cloud storage connection failed in xx ms. The level of configured provisioned throughput for the table was exceeded. Consider increasing your provisioning level with the UpdateTable API. (Service: AmazonDynamoDBv2; Status Code: 400; Error Code: ProvisionedThroughputExceededException)
  • Unable to retrieve 'Permissions' resource information. Configuration store error. AWS cloud storage connection failed in xx ms. The level of configured provisioned throughput for the table was exceeded. Consider increasing your provisioning level with the UpdateTable API. (Service: AmazonDynamoDBv2; Status Code: 400; Error Code: ProvisionedThroughputExceededException)
Cause
The ArcGIS Server Site configuration store configured was configured to use AWS Storage (DynamoDB). The configuration store contains all the essential properties of the site, including information about the machines.
The AWS DynamoDB used for the config store was set to provisioned with a read throughput limit that was insufficient to handle the spike in requests. As a result, the throughput requests were throttled causing slow performance when rendering the layers in a map.
Solution or Workaround
Updating the capacity mode set for of the AWS DynamoDB from Provisioned to On-demand resolves the issue. This is shown in the image below.
Alternatively, the provisioned limit can be increased.
Article ID: 000028222
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
