When you use VBA and attempt to delete a Geometric Network in a Personal Geodatabase, the .ldb file remains on disk.
Cause
ArcMap has a lock on the schema.
Solution or Workaround
Use ISchemaLock::ChangeSchemaLock to release the lock.
Dim pWorkspace As IWorkspace
Dim pWorkspaceFactory As IWorkspaceFactory
Dim pFeatureWorkspace As IFeatureWorkspace
Dim pDataset As IDataset
Dim pGeomNetCol As INetworkCollection
Dim pGeomNet As IGeometricNetwork
Dim pFeatureDataset As IFeatureDataset
Set pWorkspaceFactory = New AccessWorkspaceFactory
' Montgomery.mdb installs with the ArcGIS sample data
Set pWorkspace = pWorkspaceFactory.OpenFromFile("C:\Temp\Montgomery.mdb", 0)
Set pFeatureWorkspace = pWorkspace
Set pFeatureDataset = pFeatureWorkspace.OpenFeatureDataset("water")
Set pGeomNetCol = pFeatureDataset
If pGeomNetCol.GeometricNetworkCount > 0 Then
Set pGeomNet = pGeomNetCol.GeometricNetworkByName("Water_Net")
Set pDataset = pGeomNet
pDataset.Delete
' ISchemaLock::ChangeSchemaLock releases the lock
Dim pSchemaLock As ISchemaLock
Set pSchemaLock = pDataset
pSchemaLock.ChangeSchemaLock (esriSharedSchemaLock)
Set pGeomNet = Nothing
Set pDataset = Nothing
End If
Set pWorkspace = Nothing
Set pWorkspaceFactory = Nothing
Set pGeomNetCol = Nothing
Set pFeatureWorkspace = Nothing
Set pFeatureDataset = Nothing
