ERROR
When upgrading a geodatabase in DB2 from ArcGIS 9.x to ArcGIS 10.x, the Upgrade Geodatabase geoprocessing tool may fail with an error similar to the following:
"Error(Check Datasets): The geodatabase system table could not be created. [GDB_Items : Error (-51)]"
The sde_setup.log file may contain the following error:
"ERROR Creating Geodatabase tables
, Error = -511
,EXT_Error = 0
,EXT_ERROR1 = Invalid DBTUNE data found.
,EXT_ERROR2 ="
The DEFAULTS keyword of the DBTUNE table contains an invalid parameter.
This is an example of the syntax for using the sdedbtune command to remove the invalid parameter, XML_FULLTEXT_IDX_IDXDIRECTORY:
sdedbtune -o delete_data [-i <service>] -k DEFAULTS -P XML_FULLTEXT_IDX_IDXDIRECTORY [-s <server_name> ] [-D <database>] -u sde -p <SDE_password>
Article ID:000011709
Get help from ArcGIS experts
Download the Esri Support App
