PROBLEM
In ArcMap, when a table is joined to a raster attribute table, the Field Calculator may not display the fields from the joined raster, or the calculator may be completely disabled. When disabled, it is not possible to calculate the field value in a raster dataset's attribute table.
With Esri GRIDs, Field Calculator calculations fail with an error when attempting to populate a field with the values of a joined field. The error may state:
"There was a failure during processing, check the Geoprocessing Results window for details."
In the Results window, the error is 000728:
"Field XXX does not exist within table."
There are several reasons why the Field Calculator tool may be disabled on a field, and these are detailed in ArcGIS Help, Fundamentals of field calculations.
Generally, the Field Calculator does not calculate fields in a raster attribute table if the join is not permanent.
In this example, the input raster dataset is in the GRID format. The output raster dataset is a new GRID file, and the fields are saved as attributes in the new file. Once the fields are saved as attributes of the new file, the Field Calculator tool is enabled.
To export the raster data to a new file:
For this example, the raster dataset is exported to TIFF.
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012442/00N39000003LL2C-0EM39000000wdd0.jpg)
![[O]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012442/00N39000003LL2C-0EM39000000wdd4.jpg)
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012442/00N39000003LL2C-0EM39000000wdd8.jpg)
To join the table to the new raster:
1. Right-click the raster dataset in the Table Of Contents > Open Attribute Table. ![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012442/00N39000003LL2C-0EM39000000wdcw.jpg)
2. Click the Table Options drop-down > Joins and Relates > Join. ![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012442/00N39000003LL2C-0EM39000000wdd2.jpg)
3. Fill the parameters in the Join Data dialog box.
• For the field, 'Choose the field in this layer that the join will be based on', select the desired field from the table.
• For the field 'Choose the table to join to this layer, or load the table from disk', select the target table. ![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012442/00N39000003LL2C-0EM39000000wddA.jpg)
4. Click OK. The raster dataset's attribute table is now joined. ![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012442/00N39000003LL2C-0EM39000000wdd6.jpg)
To display particular fields in the joined attribute table, right-click the top of the fields, and select Turn Field Off.
Article ID: 000012442
Get help from ArcGIS experts
Start chatting now
