PROBLEM
The Feature Class To Shapefile tool fails to execute when the input feature class is in a group layer
First Published: October 19, 2016
In ArcMap, when a feature class is within a group layer, the Feature Class To Shapefile tool fails to convert the feature class to a shapefile with the following error:
Error:
Failed to convert: [Group_Layer]\[Feature_Class]. ERROR 000210: Cannot create output [File_Path\Group_Layer\Shapefile.shp]
Failed to execute (CopyFeatures).
User-added image
Cause
If a group layer is used as the input feature class, the Feature Class To Shapefile tool fails to create the output shapefile because the folder used to store the shapefile is not created.
By design, the tool appends the group layer name to the file path of the output folder specified by users. As seen in the screenshot of the error message above, the file path of the output shapefile is:
C:\Users\Username\Documents\ArcGIS\Data\New Group Layer
However, the tool fails to detect the file path to store the output shapefile because the path, with the group layer folder added, is not recognized as a valid file path.
The defect logged for this issue is NIM087577.
Solution or Workaround
Use one of the following workarounds below to solve the issue.
  • Manually create the group layer folder to store the output shapefile.
  1. In the Catalog window, right-click the desired output folder, and select New > Folder.
  2. Rename the folder to have the same name as the group layer.
  3. Run the Feature Class To Shapefile tool, using the same output location used in Step 1 for the Output Folder field in the Feature Class To Shapefile (multiple) dialog box.
  • In the Feature Class To Shapefile (multiple) dialog, instead of selecting the input feature class from the drop-down list, select the feature class directly from the stored location using the folder icon.
Image of the Feature Class To Shapefile (multiple) dialog box
  • Ungroup the layers, and run the tool again.
  • Use other tools available, such as the Feature Class To Feature Class tool or the Copy Features tool, in batch mode.
Unlike the Feature Class To Shapefile tool, each output shapefile created from the group layers must be named individually with the .shp extension when using the Feature Class To Feature Class or Copy Features tool.
Article ID: 000013917
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
