PROBLEM
The Cut command, available from the Edit menu or an element’s context menu, is not enabled when working with graphics and map elements. The shortcut Ctrl+X doesn't work either.
The Cut command is only enabled while editing features.
When working with graphics or map elements, use Copy and Delete instead.
Article ID:000003603
Get help from ArcGIS experts
Download the Esri Support App
