PROBLEM
The ArcGIS Maps for Power BI visualization fails to fully initialize using Microsoft Edge
First Published: March 15, 2018
Last Published: March 25, 2021
In some circumstances, the ArcGIS Maps for PowerBI visualization may fail to fully initialize in Microsoft Edge.
Cause
This is due to corruption of the Microsoft Edge browser. The most common workflow when this occurs as described as follows:
  1. Create a new report or load an existing report using Power BI.
  2. Add the ArcGIS Maps for Power BI visualization to the report.
  3. Add a spatial dataset, such as X/Y coordinates, or a Single Line Address, to the appropriate Power BI field well.
  4. The ArcGIS Maps for PowerBI visual may fail to fully initialize, as shown in the following image.
image of dialog box showing initialization failure
Solution or Workaround
Re-install and re-initialize the Edge browser.  To do this, Run PowerShell as Administrator and execute the following code:
Remove-Item $Env:LocalAppData\Packages\Microsoft.MicrosoftEdge* -Force -Recurse
Get-AppXPackage -AllUsers -Name Microsoft.MicrosoftEdge | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register  "$($_.InstallLocation)\AppXManifest.xml" -Verbose}
Article ID: 000017953
Software:
  • ArcGIS for Power BI
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
