PROBLEM
Text shrinks or is reduced in resultant PDF files exported from Crystal Reports for ESRI version 11. For example, text is set to Arial 10 point size in Crystal Reports, but is reduced to 8.95 point size in the exported PDF file.
This is a known issue with the Crystal Reports PDF exporter.
Warning: The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary. Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
Note: This information is taken from the Business Objects Knowledge Base article linked in the Related Information section below, but has been customized for 'Crystal Reports for ESRI' install.
Article ID: 000009203
Get help from ArcGIS experts
Start chatting now
