HOW TO
How To Take an Oracle Database Backup when requested by Esri Technical Support
Last Published: January 14, 2025
Summary
While working with Esri Technical Support, there may be times when an Oracle Database backup is requested by the Support Analyst. The Oracle Database backup may be needed for troubleshooting the issue in your Support case.
Oracle Database backups can be taken in various ways. When they are requested by Esri Technical Support, the Oracle Data Pump Export (EXPDP) utility is used to create a dump file (.DMP).
Cause
Below in the Solution is the information that must be provided and the workflow in which these tasks can be completed.
Procedure
Provide the following information regarding the Oracle Database server machine
  • Operating System and version of the server machine the Oracle Database is installed on:
    • For example: Windows 10 Enterprise 64-bit, Red Hat Enterprise Linux Server 8
  • Oracle Database version:
SELECT * FROM V$VERSION;
You may run this query in SQL*Plus when connected to the Oracle database as SYS to determine this version.
  • Enterprise Geodatabase version:
SELECT * FROM SDE.VERSION;
You may run this query in SQL*Plus when connected to the Oracle database as SYS or SDE to determine this version.
  • Are you using ST_Geometry? Based on the Operating system below, provide the version of the st_shapelib.dll or libst_shapefil.so library.
    • Windows OS
      • st_shapelib.dll:
    • Linux or Unix OS
      • libst_shapefil.so:
Execute the Get Oracle Information script and provide the resulting text file
The Get Oracle Information script (get-orainfo.sql), gathers the necessary information, (Users, Roles, Privileges, Data Owners, Tablespaces and Datafiles), to prepare for restoring an Oracle database within a different environment. This script writes the output results to C:\TEMP\ORA_Info_Results.txt. Once, the file has been generated, please provide the ORA_Info_Results.txt file to your Esri Support Services Analyst.
  1. Copy the below script and save it locally on your machine as: get-ora-backup-info.sql
  2. In SQL*Plus, connected as the SYS user, execute the get-ora-backup-info.sql script.
To execute a script file in SQL*Plus, type @ and then the file name.  See the following examples below for a variety of input options:
Example 1: If the file was called script.sql, and located in the current directory, you would type at the SQL prompt:
@script.sql
Example 2: If the file is located in a different directory, add the path prior to the file name.
@/oracle/scripts/script.sql
  1. Provide this output ORA_Info_Results.txt file to the Esri Support Services analyst.
clear screen
PROMPT
PROMPT
PROMPT ********************************************************************************
PROMPT * Script to gather information about an Oracle instance for backup and restore *
PROMPT
PROMPT
sho user
PROMPT
PROMPT
PROMPT This script needs to be executed as the SYS or SYSTEM user, or with a user that has been assigned the DBA role!!
PROMPT
PROMPT
PAUSE  Press CTRL+C to quit, or press any key to continue ...
PROMPT
CLEAR BREAKS COMPUTES COLUMNS
host mkdir C:\TEMP
spool C:\TEMP\ORA_Backup_Info_Results.txt replace
set linesize 130 pages 500
col member for a80
col "Filesize in MBs" for 9,999,999.99
PROMPT
PROMPT
PROMPT
PROMPT * INFORMATION GATHERED WILL BE USED BY ESRI *
PROMPT *  SUPPORT TO RESTORE THIS ORACLE DATABASE  *
PROMPT
PROMPT
PROMPT
PROMPT * SID, ORA VERSION, HOSTNAME INFO *
col "HOST NAME" for a20
select instance_name, version "ORA VERSION", substr(host_name,1,30) "HOST NAME", active_state "STATE", archiver "ARCHIVE"
from v$instance;
PROMPT
PROMPT
PROMPT
PROMPT * TABLESPACE INFO *
COL c1 heading "Tablespace Name" FORMAT A25
COL c2 heading "Used MB"    	 FORMAT 99,999,999
COL c3 heading "Free MB"    	 FORMAT 99,999,999
COL c4 heading "Total MB"   	 FORMAT 99,999,999
break on report
compute sum of c2 on report
compute sum of c3 on report
compute sum of c4 on report
SELECT
   fs.tablespace_name              c1,
   (df.totalspace - fs.freespace)  c2,
   fs.freespace                    c3,
   df.totalspace                   c4,
   round(100 * (fs.freespace / df.totalspace)) "% Free"
FROM (select distinct tablespace_name, round(sum(bytes) / 1048576) TotalSpace
     from dba_data_files group by tablespace_name) df,
     (select tablespace_name, round(sum(bytes) / 1048576) FreeSpace
     from dba_free_space group by tablespace_name) fs
WHERE df.tablespace_name = fs.tablespace_name
ORDER BY 1;
PROMPT
PROMPT
PROMPT
/* PROMPT **************************
PROMPT * TABLESPACE EXTENT INFO *
select tablespace_name, block_size, segment_space_management, initial_extent "INITIAL_EXT", next_extent "NEXT_EXT",      extent_management "EXT_MGMT", allocation_type "ALLO_TYPE"
from dba_tablespaces
order by 1;
PROMPT
PROMPT
PROMPT */
PROMPT * Non ORACLE GENERATED TABLESPACE METADATA INFO *
set long 9999999
select dbms_metadata.get_ddl('TABLESPACE',tbsp.tablespace_name)
from dba_tablespaces tbsp
where tablespace_name not in('SYSTEM','SYSAUX','UNDOTBS1','TEMP','USERS');
PROMPT
PROMPT
PROMPT
PROMPT * USER METADATA INFO *
PROMPT
PROMPT
select dbms_metadata.get_ddl('USER',usr.username)
from dba_users usr;
PROMPT
PROMPT
PROMPT */
PROMPT * USER INFO *
PROMPT
PROMPT
PROMPT
PROMPT
PROMPT All non-Oracle maintained users in the database
PROMPT ===============================================
col username for a30
col default_tablespace for a20
col temp_tablespace for a20
col profile for a20
col account_status for a20
select username,substr(default_tablespace,1,30) default_tablespace, substr(temporary_tablespace,1,20) temp_tablespace, substr(profile,1,20) profile, substr(account_status,1,20) account_status
from dba_users
where oracle_maintained = 'N'
order by 1;
PROMPT
PROMPT
PROMPT Users that own data in SDE
PROMPT
PROMPT
PROMPT SDE Layers
PROMPT -----------
col owner for a20
select owner,count(*) from sde.layers group by owner order by 1;
PROMPT
PROMPT
PROMPT SDE Tables
PROMPT -----------
col owner for a20
select owner,count(*) from sde.table_registry group by owner order by 1;
PROMPT
PROMPT
PROMPT ST_Geometry Layers
PROMPT -------------------
col owner for a20
select owner,count(*) from sde.st_geometry_columns group by owner order by 1;
PROMPT
PROMPT
PROMPT
PROMPT Number of Columns in SDE Tables
PROMPT --------------------------------
col tablename for a60
select owner||'.'||table_name tablename, count(*) NumColumns from sde.column_registry group by owner||'.'||table_name order by 2 desc ;
PROMPT
PROMPT
PROMPT
PROMPT * USER PRIVILEGES INFO *
PROMPT
PROMPT Privileges assigned to users that own data in ArcSDE
PROMPT ====================================================
col username for a20
col PRIVILEGES_ASSIGNED for a30
break on username skip 1
select grantee username, granted_role PRIVILEGES_ASSIGNED
from dba_role_privs
where grantee in (select distinct owner from sde.table_registry
                  union
                  select distinct owner from sde.st_geometry_columns
                  union
                  select distinct owner from sde.layers)
union
select grantee "USERNAME", privilege "PRIVILEGES ASSIGNED"
from dba_sys_privs
                  union
                  union
order by 1;
PROMPT
PROMPT
PROMPT
PROMPT
PROMPT * SDE VERSION INFO *
select major,minor,bugfix,description  from sde.version;
PROMPT
PROMPT
PROMPT
spool off
host notepad C:\TEMP\ORA_Backup_Info_Results.txt
    Use the Data Pump Export (EXPDP) utility to create a dump file
    1. As the SYS user, using SQL*Plus, connect to the Oracle instance to generate Oracle export file. Below is an example of how the format is used to connect in SQL*Plus.
    sqlplus sys/sys@server/sid as sysdba
    1. Verify if a directory exists to write the Oracle dump file to. The directory name by default is ‘DATA_PUMP_DIR’. This directory is where the Oracle dump file(s) are written to. The directory name is ‘DATA_PUMP_DIR’. You may use the following query to determine the directory path.
    select * from dba_directories where directory_name = ‘DATA_PUMP_DIR’;
    Example: C:\app\oracle\admin\db_unique_name\dpump\
    1. If a directory does not already exist, create one.  Use the following example as a guide, updating the name and path for your environment.  This example creates a directory called DATA_PUMP_DIR.  The Oracle dump file(s) will be written to subdirectories within Oracle's Admin Directory, ORACLE_BASE\admin\DB_UNIQUE_NAME.
    create directory ‘DATA_PUMP_DIR’ as 'C:\app\oracle\admin\DB_UNIQUE_NAME\dpump\';
    1. Use the following command to exit SQL*Plus.
    quit;
    1. Open Command Prompt on this machine and generate a full Oracle dump file using the following command with the Data Pump Export (EXPDP) utility.
    expdp user_name FULL=y DUMPFILE=expdat.dmp DIRECTORY=data_pump_dir LOGFILE=export.log
    Note (Optional):
    To export individual schemas (sde.dmp, gis.dmp, etc...) use the syntax below.
    expdp user_name DUMPFILE=expdat.dmp DIRECTORY=data_pump_dir LOGFILE=export.log schemas=SDE
    Provide the Oracle Dump File(s) (.DMP) file to your Esri Technical Support Analyst.
    • Now that the Oracle Dump File(s) have been generated, upload these along with your log files to the secure location provided by your Esri Technical Support Analyst. If you have not, received this File Transfer Site, reach out to the Esri Technical Support Analyst you are working with on your case.
    • To ensure that there are no issues with data corruption upon upload, please check the size of the data uploaded to the File Transfer Site to the size that you have locally on your machine.
    Consult with your Organization's Database Administrator or IT and refer to Oracle documentation for assistance with the Oracle Data Pump Export (EXPDP) utility.
    Article ID: 000026410
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
