ERROR
Note: This article applies to ArcGIS versions 8.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
When building a geometric network on SDE the following error occurs:
"Table not registered [Table name]"
This problem was addressed in ArcGIS 8.1 Service Pack 1. See the Related Information section.
The geometric network has a keyword whose tablespace is too small.
The error message depends on the size of the tablespace assigned to the configuration keyword. The build process could fail at any point during the creation of the network tables, resulting in a slightly different error message. Generally it will resemble the error message listed above.
Increase the size of the tablespace assigned to the keyword or use a keyword whose tablespace is large enough to hold the network tables.
Article ID:000003632
Get help from ArcGIS experts
Download the Esri Support App
