HOW TO
Sync a data store item with a Python script using token-based authentication
Last Published: September 12, 2023
Summary
Starting with Portal for ArcGIS 10.7.1, users can register user-manager data stores by adding a data store item to the portal. When a user's create data stores items in their portal organization, it allows users to create web layers in bulk from the items inside the enterprise geodatabase.
When items are added or removed from the enterprise geodatabase, users can manually synchronize the enterprise geodatabase with the data store item in the portal. However, some users may want to automate the syncing process using a Python script.
Procedure
Below is one method to synchronize the data store item with Python:
import urllib, urllib2, json, ssl, arcpy, requests
# Generate Portal token
username = "<enter user name>"
password = "<enter password>"
tokenURL = 'https://<enter portal URL>/portal/sharing/rest/generateToken/'
param_1 = {'f': 'pjson', 'username': username, 'password': password, 'referer': 'https://<enter portal URL without web adaptor>'}
req = urllib2.Request(tokenURL, urllib.urlencode(param_1))
try:
    response = urllib2.urlopen(req)
except:
    gcontext = ssl.SSLContext(ssl.PROTOCOL_TLSv1_2)
    response = urllib2.urlopen(req, context=gcontext)
data = json.load(response)
token = data['token']
print(token)
# Sync the Data Store item in Portal
publishURL = 'https://<enter portal URL>/portal/sharing/rest/portals/self/datastores/allDatasets/publishLayers'
param_2 = {'datastoreId': '<enter datastore ID>',
                   'templateSvcConfig': {"serviceName":'null',"type":"MapServer","capabilities":"Map,Query","extensions":[{"typeName":"FeatureServer","capabilities":"Query","enabled":"true","properties":{"maxRecordCount":"4000"}}]},
                   'f': 'json',
                   'token': token}
req = urllib2.Request(publishURL, urllib.urlencode(param_2))
try:
except:
print('Syncing')
Article ID: 000022854
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
