HOW TO
Switch between different basemaps using the Flex HSlider control
Summary
Instructions provided describe a method for switching between basemaps using the HSlider control.
This sample shows the way of allowing users to switch between different basemaps by using the HSlider control in Adobe Flex 4 SDK. The HSlider control lets user select a basemap by moving the slider thumb between the end points of the slider track.
One of the easiest ways to experiment with this is by simply creating a blank Flex application, adding a reference to the appropriate Esri Flex API swc file, copying the following code snippet in the mxml page, and finally building and executing the application to load it in a browser.
[O-Image]
Procedure
Code:
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="https://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:esri="https://www.esri.com/2008/ags"
xmlns:mx="library://ns.adobe.com/flex/mx"
pageTitle="Toggle between Map Services with HSlider Control">
<fx:Style>
@namespace s "library://ns.adobe.com/flex/spark";
@namespace mx "library://ns.adobe.com/flex/mx";
.customHSliderStyle{
color: White;
</fx:Style>
<fx:Script>
<![CDATA[
import com.esri.ags.geometry.MapPoint;
import com.esri.ags.layers.TiledMapServiceLayer;
import mx.events.FlexEvent;
private function layerShowHandler(event:FlexEvent):void
var tiledLayer:TiledMapServiceLayer = event.target as TiledMapServiceLayer;
myMap.lods = tiledLayer.tileInfo.lods;
</fx:Script>
<esri:Map id="myMap" level="4" load="myMap.centerAt(new MapPoint(-11713000, 4822000))">
<esri:ArcGISTiledMapServiceLayer show="layerShowHandler(event)"
url="https://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"
visible="{hSlider.value == 0}"/>
url="https://server.arcgisonline.com/ArcGIS/rest/services/USA_Topo_Maps/MapServer"
visible="{hSlider.value == 1}"/>
url="https://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"
visible="{hSlider.value == 2}"/>
</esri:Map>
<s:VGroup right="10" top="10">
<mx:VBox borderStyle="solid" borderColor="white" backgroundColor="black" backgroundAlpha="0.7" cornerRadius="10">
<mx:Label width="280" color="red" paddingTop="10" paddingLeft="10" fontWeight="bold"
text="Use the slider to switch the base map layers" />
<mx:HSlider id="hSlider" maximum="2" snapInterval="1" tickInterval="1" width="300" labelStyleName="customHSliderStyle"
labels="['Streets', 'U.S. Topo','Imagery']" />
</mx:VBox>
</s:VGroup>
</s:Application>
    Article ID: 000011306
    Software:
    • ArcGIS API for Flex Prev
    • ArcGIS API for JavaScript Prev
    Get support with AI
    Start chatting now
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
