ERROR
Survey submissions fail with "Failed to submit. Field {fieldName} has invalid HTML content" or "Unable to apply edits"
First Published: February 6, 2026
Last Published: February 6, 2026
Error Message
When submitting an ArcGIS Survey123 survey record, the submission fails with the following error messages:
  • “Failed to submit. Field {fieldName} has invalid HTML content.”
  • “Unable to apply edits.”
This error occurs when the submitted value contains HTML-like characters, such as < or >.
Cause
The feature service has cross-site scripting (XSS) prevention enabled. The input content is validated based on the service’s xssPreventionInfo configuration. If the submission contains HTML-like input that is not allowed, the feature service rejects the edit and returns the error.
Solution or Workaround
Update the feature service’s xssPreventionInfo settings to allow or sanitize HTML-like input:
  • Keep XSSPreventionEnabled as true and set xssInputRule to sanitizeInvalid. This sanitizes invalid HTML content instead of rejecting the submission
  • Set xssPreventionEnabled to false to disable XSS prevention.
Warning:
Disabling XSS prevention can introduce security risks. Only do this in trusted environments and when you fully understand the security implications.
If only certain fields are necessary to accept HTML-like content, configure the feature layer’s xssTrustedFields so these fields are treated as trusted and excluded from the XSS filtering behavior.
Warning:
Marking fields as trusted can increase security risk. Only trust fields when you understand the impact and the data source is trusted.
Article ID: 000040192
Software:
  • ArcGIS Survey123
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
