PROBLEM
Surface protrudes through draped polygons in ArcScene
A draped polygon is interrupted by surface features.
Cause
Polygons are a string of X,Y, and sometimes Z coordinates that define the boundary of an area. No coordinates are stored for the internal area of the polygon. ArcScene uses the vertices of the polygon boundary to define its height in the scene. However no interpolation is done on the internal area of the polygon. If the surface has a spire or other feature higher than the height of the polygon's edge, the surface protrudes through the polygon.
Solution or Workaround
Convert the polygons to rasters. Rasters draped over a surface are interpolated at the center of each cell; therefore, the entire area of the raster is interpolated.
  • For ArcGIS versions 8.3 and earlier, use the Features to Raster tool found under Spatial Analyst > Convert.
  • For ArcGIS versions 9.0 and later, use the Feature to Raster tool found in ArcToolbox > Conversion > To Raster.
Article ID:000007820
Software:
  • ArcMap
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
