ERROR
Using ERASE or ELIMINATE on complex polygon coverages, or on a selection set that includes the universe polygon, produces the following error:
Error:
Statistics array limit (POLSCN)
ISP channel# 1 was not properly closed (INFEND)
Bailing out of BUILD
The error indicates a software array size limitation when ERASE or ELIMINATE are used with large complex polygon coverages, or coverages that include the universe polygon in the area to be erased or eliminated.
Code: Arc: eliminate soils soilsel Enter a logical expression: reselect soils# ne 1 Do you wish to re-enter expression (Y/N)? N Do you wish to enter another expression (Y/N)? Y Enter a logical expression: res area < 40000 Do you wish to re-enter expression (Y/N)? N Do you wish to enter another expression (Y/N)? N
Article ID: 000002414
Get help from ArcGIS experts
Start chatting now
