PROBLEM
When executing SQL statements with Oracle 11g containing st_geometry operators, performance, when compared with Oracle 10g, is significantly worse.
In addition, when an Oracle session calls out to the external process to access a shared library, the Oracle Heterogeneous Agent creates a file in the directory Oracle\product\11.1.0\db_1\hs\trace named PLSExtProc_agt_<pid>.trc, where <pid> is the value of the session's process identifier.
Below is the text that is visible when expecting the file:
Code:
Oracle Corporation --- TUESDAY MAR 11 2008 20:14:27.156
Heterogeneous Agent Release
11.1.0.6.0
Unable to open init file in directory D:\Oracle\product\11.1.0\db_1/hs/admin_
Unable to open init file _¢�`ø Ò_¼�¬`”
�_Ì
�_´§Ñ_�<�_ in directory D:\Oracle\product\11.1.0\db_1/hs/admin_
On each call to the extproc the same error message is written -
�_Ì
�_´§Ñ_ì<�_D:\O_ in directory D:\Oracle\product\11.1.0\db_1/hs/admin_
The cause of the problem is unknown.
It appears as if debug statements in the Oracle server were mistakenly left enabled, and are therefore logging information for every session performing calls to an external library, which will have a negative impact on performance.
Article ID:000010187
Get help from ArcGIS experts
Download the Esri Support App
