ERROR
SQL Connect: Failed to get the expression service
Solution or Workaround
Error Message
While connecting to the Access database, the following error may occur:
Call to SQLDriverConnect recieved error
Received: SQL_ERROR
Return code: -1
State: S1000
Error: [Microsoft][ODBC Microsoft Access 97 Driver]General error
Failed to
File: ..\sql\ntcon.c
Line: 268
Cause
Outdated ODBC driver
Solution
Warning:
WARNING: The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary.
ESRI cannot guarantee results from incorrect modifications while following these instructions. Therefore, use caution and proceed at your own risk.
Download and install the latest drivers for the database. Currently, you can download the MS ODBC drivers from:
http://www.microsoft.com/data/mdac2.htm
You must first accept the license agreement at the bottom of the page. From the next page select for download "Microsoft Data Access Components 2.0 SP2 Redistribution Typical Setup". This pack contains core MDAC 2.0 components including additional OLE DB providers and ODBC drivers for various data sources, including the drivers for Excel and Access.
Article ID:000001550
Software:
  • Legacy Products
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
