HOW TO
In the Review/Rematch Addresses dialog box, there are several options available for specifying which addresses to rematch. Each of these options can be represented by a SQL WHERE clause that specifies which records in the geocoded shapefile or feature class to rematch.
The following table shows the equivalent SQL WHERE clauses for the rematch options available in the Review/Rematch Addresses dialog box:
You can also qualify one of these options using additional SQL WHERE clauses. In the Review/Rematch Addresses dialog box, check the 'in this query option'. The Query Window dialog box that appears will let you specify additional WHERE clauses to restrict which addresses you want to rematch.
Currently, you cannot use a spatial filter to restrict which addresses you want to rematch.
Article ID:000003600
Get help from ArcGIS experts
Download the Esri Support App
