Summary
                    When performing the batch Geocode Addresses operation on a geocode service, the returned output fields differ from that of the Find Address Candidates operation. Specifically, Geocode Addresses shows less output fields. This is because batch_mode = false in ArcGIS Desktop's USAddress.lot.xml file for those various output fields. The steps provided describe how to change this so that all fields are part of the output.
                        Procedure
                    - Open the USAddress.lot.xml file located at:
C:\Program Files (x86)\ArcGIS\Desktop10.3\Locators
- Starting at line 26857, the fields specified by "<output ref" show whether "batch_mode" is true or false. To allow for these fields to be displayed in the Geocode Addresses operation, change these to "batch_mode=true".
	- Find and replace "batch_mode=false" with "batch_mode=true" would work fine here.
- If the locator and geocode service are already published, it is necessary to recreate the locator from the ground up after completing the above step.
 After re-creating and publishing as a geocode service, note that all fields are part of the output when performing the Geocode Addresses operation.
