BUG
An ORA-028579 error can be encountered when executing a query with an st_geometry attribute.
Code:
SELECT objectid,
sde.st_intersection(shape,
(SELECT shape
FROM parcels
WHERE id = 4 AND cycle_type = '1')) AS shape
FROM parcels
WHERE sde.st_intersects(shape,
(SELECT shape
FROM parcels
WHERE id = 4 AND cycle_type = '1')) = 1;
This issue is due to an Oracle bug. Refer to My Oracle Support for more information.
Oracle Bug: 8507458 "ODCIindexstart dump on select on a column which has domain index created."
If the problem described in this article is encountered, a new folder and call stack trace file will be automatically generated by Oracle in the $ORACLE_HOME/rdbms/log/hs_core_#### folder (where #### is an auto-generated number). This call stack trace can be compared to the one mentioned in the Oracle bug, or it can be provided to Oracle to determine if the same issue is being encountered.
Article ID:000011218
Get help from ArcGIS experts
Download the Esri Support App
