ERROR
Sorry, an error has occurred. The application could not be installed because the installer file is damaged. Try obtaining a new installer file
Last Published: April 26, 2020
Error Message
When installing Esri Maps Designer for SAP BusinessObjects, the following error message may be returned:
"Sorry, an error has occurred. The application could not be installed because the installer file is damaged. Try obtaining a new installer file from the application author."
Cause
This error may occur because of a corrupt download of the install files or the installer is on a network location.
Solution or Workaround
• Try re-downloading the file as it might be corrupted or there was an incomplete download.
• Copy the installer and run it locally rather than running the install from a network location.
    Article ID: 000012302
    Software:
    • Legacy Products
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
