ERROR
When upgrading an older version of Esri Maps for SAP BusinessObjects, the following error message may be returned.
“Sorry, an error has occurred.
The application cannot be installed due to a certificate problem. The certificate does not match the installed application certificate, does not support application updates, or is invalid. Please contact the application author.” ![[O-Image] AIR certificate invalid](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012358/00N39000003LL24-0EM39000000wdac.png)
This error occurs when the Adobe AIR (Adobe Integrated Runtime) certificate used to sign the installed Esri Maps Designer application is different from the certificate used to sign the newer version of the Esri Maps Designer application.
Article ID: 000012358
Get help from ArcGIS experts
Start chatting now
