PROBLEM
Some numeric fields, which should be offered for tag value use on the TIN Builder dialog box, are not listed when the input is a shapefile.
This is a known problem. Certain restrictions in how numeric fields are defined in dBASE prevent an integer interpretation of the fields in question. Tag values must be integer.
Article ID:000004329
Get help from ArcGIS experts
Download the Esri Support App
