PROBLEM
Some folders are missing from Business Analyst Server Data
After uninstalling ArcGIS Business Analyst 9.3 Desktop extension, some data folders in ArcGIS Business Analyst Server Data - 2008 are missing; even though, ArcGIS Business Analyst Server Data - 2008 was not uninstalled.
Cause
Uninstalling ArcGIS Business Analyst 9.3 Desktop extension uninstalls some data folders that are installed by ArcGIS Business Analyst Server Data - 2008 setup.
Solution or Workaround
The missing folders can be reclaimed by running the Repair process.
To run the Repair process:
  1. In Windows, select Start > Control Panel.
  2. Select Add or Remove Programs.
  3. Select ArcGIS Business Analyst Server Data - 2008.
  4. Select Change.
    This launches the ArcGIS Business Analyst Server Data - 2008 Setup process.
  5. Select Repair.
    This repairs the ArcGIS Business Analyst Server Data - 2008 installation. It reinstalls the data folders removed by the uninstall of ArcGIS Business Analyst 9.3 Desktop extension.
Article ID: 000010514
Software:
  • ArcGIS Business Analyst Enterprise
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
