PROBLEM
Some editable layers cannot participate in a map topology
Upon opening the Map Topology dialog box and checking layers in the list to be included in the topology, some of the layers have been unchecked when the dialog box is reopened. In addition, those layers are not affected by any shared feature edits.
Cause
Some layers are being projected on the fly.
Solution or Workaround
To participate in a map topology, the projections of all the layers and the data frame need to be the same. This may mean that either the layers need to be reprojected so they match other layers, or the projection of the data frame needs to be changed to match the layers.
  1. To change the coordinate system of the data frame, such as to make the data frame match a particular layer, see Specifying a coordinate system.
    Stop the edit session before doing this.
  2. To project a layer to match other layers, use the Project geoprocessing tool: Project (Data Management).
  3. Once all the projections match, start an edit session.
  4. Open the Map Topology dialog box again, and check the layers that will participate in the map topology. The layers will now be affected by shared edits.
Article ID: 000010721
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
