PROBLEM
Some ArcMap features do not display when symbolizing proportional values
First Published: May 5, 2016
The proportional symbols method can cause some features not to display.
Cause
The proportional symbols method only works with positive values. If the value field has values less than or equal to zero, a message box will alert you of the exclusion these values. If these values are not excluded, the features will not be drawn.
Solution or Workaround
Exclude values less than or equal to zero.
  1. Click the Exclude button on the Proportional Symbols dialog box.
  2. Build an exclusion query.
    A. Click the Query tab.
    C. Double-click the field with exclusion value.
    D. Double-click an operator.
    E. Double-click the value exclusion value. If value isn't listed, click the Complete List button.
    F. Click Apply to execute the expression and exclude values.
    [O-Image] Using exclusion
  3. Click a symbol to display the excluded data.
    [O-Image] Exclusion symbol
Article ID: 000002848
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
