PROBLEM
Snapping does not function while editing data in ArcMap
While editing, the snapping commands fail to function as expected. Features cannot be connected because the pointer does not snap to edges and vertices in the map document.
The pointer not snapping to an edge of a feature in a map document
Cause
This issue may be caused by one of the following:
  • Snapping option is disabled.
  • The current editing session is not active.
  • Map document is displayed in layout view.
    Layout view is used when creating a map. It is recommended to perform edits when the map is displayed in data view. The ability to snap is not possible in layout view as the command cannot interact with the data.
  • Data or map document is corrupted.
    If either the data or document is corrupted, it is not possible to make changes to the map.
  • Snapping tolerance not set correctly.
    The pointer automatically snaps to a vertex or edge if the distance of the pointer from a feature is within the snapping tolerance. If the tolerance is set too low – such as 0 – snapping does not occur.
Solution or Workaround
Follow the steps provided below to resolve this issue.
  1. Ensure the Use Snapping setting is enabled. Refer to ArcMap: Enabling snapping for more information.
Enabling snapping from the Snapping menu on the Snapping toolbar.
  1. Ensure the map document is displayed in data view. Refer to ArcMap: Displaying maps in data view and layout view for more information.
Switching to data view from the bottom left of ArcMap or from View > Data View
If the snapping commands do not function after following the above steps, use the options provided below until the issue is resolved.
Restart the editing session
  1. Close the current editing session, if a session is open.
  2. Begin a new editing session. Refer to ArcMap: Starting an edit session (Start Editing) for the steps to do this.
Export the data to a new blank map document
  1. Create a new blank template in ArcMap.
  2. Use either the Export Data or Add Data command. Refer to ArcMap: Exporting selected features with the Export Data command and ArcMap: Adding layers to a map for more information on these commands.
Warning:
Do not copy and paste, or drag and drop the data from one file to another as this may carry over any data or file corruption.
Set the snapping tolerance to a higher pixel
Refer to ArcMap: Setting the snapping tolerance for the steps to do this.
Ensure the End Snap button is highlighted on the Snapping toolbar.
Article ID: 000012235
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
