PROBLEM
When trying to set map tips for a shapefile, the Show Map Tips option is disabled in the Layer Properties dialog box.
The shapefile does not have a spatial index.
If the Add button is disabled, the shapefile may be locked by ArcMap. Save the map document and close ArcMap; then, try the above steps.
Article ID:000004635
Get help from ArcGIS experts
Download the Esri Support App
