HOW TO
Setup regional settings (locale) on Unix for ArcMap Server and ArcReader
Summary
Regional Settings for ArcMap Services on Unix can be set by using the MainWin Control Panel (mwcontrol).
In ArcIMS 9.2, the setup of regional locale is automated based on the current locale.
The procedure outlined here is applicable when regional settings need to changed manually.
Procedure
Follow the steps below.
  1. Open a terminal on the machine where ArcMap server is installed.
  2. At the command prompt type:
    Code:
    cd $AIMSHOME/qs_scripts
    ./stop_arcims
  3. At the command prompt type:
    Code:
    source $AIMSHOME/../init_engine.csh
    mwcontrol
    This opens the MainWin Control Panel.
  4. Click the 'Regional Settings' icon to open the Regional Settings Properties dialog box.
  5. On the Regional Settings tab, select the required locale. This locale should match with the System Locale of the ArcIMS user.
    • Check the 'Set as System default Locale' option in the bottom of the dialog.
    • If required, specify the Number, Currency, Time and Date options in this dialog.
  6. Click OK to accept the settings and to close the Regional Settings Properties dialog window.
  7. Close the MainWin Control Panel.
  8. In the command prompt type:
    Code:
    mwadm stop
    This stops the MainWin Core Services.
  9. In the command prompt type:
    Code:
    mwadm start
    This starts the MainWin Core Services.
  10. Open a new terminal. At the command prompt type:
    Code:
    ./start_arcims
Article ID:000006888
Software:
  • ArcReader
  • Legacy Products
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
