HOW TO
Set up direct connect for DB2 with ArcGIS Server on Linux
Summary
Instructions provided describe how to set up the arcsoc.init file to include the environment variables necessary for performing DB2 direct connect.
Procedure
  1. Stop server:
    Code:
    <arcgis directory>/scripts/stopserver
    In version 10.0, <arcgis directory> is the path to the server10.0 directory inside the arcgis directory. In previous versions, <arcgis directory> is the path to the arcgis directory.
  2. Make a backup of the <arcgis directory>/bin/arcsoc.init file:
    Code:
    cp <arcgis directory>/bin/arcsoc.init <arcgis directory>/bin/arcsoc.init.orig
  3. For DB2 Client version 8.x, set the following variables in the <arcgis directory>/bin/arcsoc.init file just before the exec $* statement:
    Code:
    SDEHOME=<arcgis directory>;export SDEHOME
    DB2_CLIENT_HOME=<DB2 client directory location>;export DB2_CLIENT_HOME
    DB2INSTANCE=<DB2 instance name>;export DB2INSTANCE
    LD_LIBRARY_PATH="$LD_LIBRARY_PATH:$SDEHOME/bin:$DB2_CLIENT_HOME/lib";export LD_LIBRARY_PATH
    PATH="$PATH:$SDEHOME/bin:$DB2_CLIENT_HOME/bin:$DB2_CLIENT_HOME/adm:$DB2_CLIENT_HOME/misc";export PATH
    For example, with ArcGIS Server installed to /dir1/arcgis, DB2 Client located in /dir1/db2_81/db2udb/sqllib and DB2 instance named db2udb, the settings would be:
    Code:
    SDEHOME=/dir1/arcgis;export SDEHOME
    DB2_CLIENT_HOME=/dir1/db2_81/db2udb/sqllib;export DB2_CLIENT_HOME
    DB2INSTANCE=db2udb;export DB2INSTANCE
    For DB2 Client version 9.x, set the following variables in the <arcgis directory>/bin/arcsoc.init file just before the exec $* statement:
    Code:
    LD_LIBRARY_PATH="$LD_LIBRARY_PATH:$SDEHOME/bin:$DB2_CLIENT_HOME/lib32";export LD_LIBRARY_PATH
    PATH="$PATH:$SDEHOME/bin:$DB2_CLIENT_HOME/bin:$DB2_CLIENT_HOME/adm";export PATH
    For example, with ArcGIS Server installed to /dir1/arcgis, DB2 Client located in /dir1/db2_91/db2udb/sqllib and DB2 instance named db2udb, the settings would be:
    Code:
    DB2_CLIENT_HOME=/dir1/db2_91/db2udb/sqllib;export DB2_CLIENT_HOME
  4. Start server:
    Code:
    <arcgis directory>/scripts/startserver
Article ID: 000010206
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
