HOW TO
Note: Troubleshooting graphic cards is beyond Esri's Scope of Support, and it is advisable to follow the workaround described in the Esri Knowledge Base article: Problem: Graphics card conflict may cause ArcGIS Pro to crash.
This workaround can be applied to desktop applications such as ArcGIS Pro, or ArcGIS Drone2Map when they crash due to a graphics card conflict.
It is important to note that this workaround only works if the computer has more than one graphics card. If it does not resolve the issue, further investigation by the IT department is required to troubleshoot the affected graphics card. In this case, the computer should have more than one graphics card. This can be verified by opening Windows Device Manager > Display adapters.
C:\Program Files\ArcGIS\Pro\bin\ArcGISPro.exe
C:\Program Files\ArcGIS\Drone2Map\bin\Drone2Map.exe
Article ID: 000025975
Get help from ArcGIS experts
Start chatting now
