HOW TO
The sample scripts in this article demonstrate how to set symbols for a theme.
Code:
'-- Create a new theme from a feature source:
theView = av.GetProject.FindDoc("View1")
'-- This line has to be changed for line themes. Use arc instead
'-- of point for feature type. You will need to make changes
'-- to the path where your data resides.
theTheme = Theme.Make("c:\esri\esridata\usa\cities.shp".AsSrcName)
theTheme.SetName("Calif Cities")
theView.AddTheme(theTheme)
theTheme.SetVisible(true)
theTheme.SetActive(true)
theLegend = theTheme.GetLegend
NewLegend = theLegend.Clone
'-- Refer the symbol palette for the number to be used with Get().
'-- For line themes use #PALETTE_LIST_PEN instead of #PALETTE_LIST_MARKER.
CurrSymbol = av.GetSymbolWin.GetPalette.GetList(#PALETTE_LIST_MARKER).Get(1)
NewSymbol = Symbol.Make(#SYMBOL_MARKER)
NewSymbol.Copy(CurrSymbol)
NewSymbol.SetColor(Color.GetRed)
NewSymbol.SetSize(6)
NewLegend.GetSymbols.Set(0, NewSymbol)
'-- Refresh the theme without refreshing other themes in the view.
theTheme.SetLegend(NewLegend)
theTheme.InvalidateLegend
theTheme.UpdateLegend
Code:
'-- You will need to make changes to the path where your data resides.
theTheme = Theme.Make("c:\esri\esridata\usa\counties.shp".AsSrcName)
theTheme.SetName("USA Counties")
'-- Modified lines.
'-- This returns a COLOR object, not a SYMBOL; thus, create a
'-- new symbol and set its color using this returned object.
NewCol = av.GetSymbolWin.GetPalette.GetList(#PALETTE_LIST_COLOR).Get(9)
NewSymbol = Symbol.Make(#SYMBOL_FILL)
NewSymbol.SetColor(NewCol)
NewLegend = theLegend.GetSymbols.Set(0, NewSymbol)
Code:
'-- Sample script to manipulate the Legend of a theme
'-- and its classifications (Values and Labels)
'-- The example uses a legend with three classifications.
'-- Gets the view
'-- Get the theme. Use sample data in AVDATA. If other themes are
'-- used, the values for classification should be changed.
theTheme = theView.FindTheme("States")
'-- Get legend and corresponding classifications.
theClasses = theLegend.GetClassifications
'-- Define the shade symbol for all the unselected countries.
b = Symbol.Make(#SYMBOL_FILL)
b.SetColor(Color.GetRed)
b.SetOlColor(Color.GetBlack)
'-- Update the legend with this symbol. This symbol is added as
'-- the first element in the legend's symbol list.
theLegend.GetSymbols.Set(0,b)
'-- Define the shade symbol for the selected country.
c = Symbol.Make(#SYMBOL_FILL)
c.SetColor(Color.GetGreen)
c.SetOlColor(Color.GetBlack)
'-- as the second element in the legend's symbol list.
'-- Symbol b is again added to the symbol list as the third element.
theLegend.GetSymbols.Set(1,c)
theLegend.GetSymbols.Set(2,b)
'-- Manipulate the classification values and labels
i = theClasses.Get(0)
i.SetMinimum(1)
i.SetMaximum(39)
i.SetLabel("1 - 39")
i = theClasses.Get(1)
i.setMinimum(40)
i.SetMaximum(40)
i.SetLabel("40")
i = theClasses.Get(2)
i.SetMinimum(41)
i.SetMaximum(51)
i.SetLabel("41-51")
'-- Update the theme with the new shades.
theview.invalidate
Article ID:000003933
Get help from ArcGIS experts
Download the Esri Support App
