HOW TO
Set a proxy in the Web AppBuilder (Developer Edition)
Summary
The Developer edition of Web AppBuilder supports the option to set an outbound proxy. This may be useful if it is required to use a proxy to communicate with external URLs such as arcgis.com from the computer running Web AppBuilder.
Procedure
The documentation related to this article covers the option of adding a proxy and port setting when running Web AppBuilder from the command line. Another option if using the Windows version of node.js, is to edit the startup.bat file that comes with the web app builder.
  1. In a text editor, open the startup.bat file. On line number 29 of the bat file there should be the following text.
    [O-Image]
  2. Specify -proxy:port on this line after the startup parameters as follows:
------>START "Web AppBuilder for ArcGIS" /B %nodefile% %serverjsfile% -proxy="https://USERNAME:PASSWORD@proxy:80"
[O-Image]
Article ID: 000013274
Software:
  • ArcGIS Web AppBuilder
  • ArcGIS Enterprise 10 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
