HOW TO
Set a map document's properties using ArcObjects
Summary
In ArcMap, there is a Map Document Properties dialog that shows the following information fields about the .mxd file: Title, Summary, Description, Author, Credits, Tags and Hyperlink base.
The Map Document Properties dialog box
[O-Image]
Instructions provided describe how to access and changes these properties via the IDocumentInfo2 interface.
Procedure
The samples below show how to change the author, title, and description of the document.
  • VB.NET Sample
    Code:
    Dim pMapDoc As IMapDocument = New MapDocument()
    pMapDoc.Open("C:\\Untitled.mxd")
    Dim pDocInfo As IDocumentInfo2 = pMapDoc
    'Change the author of the document
    pDocInfo.Author = "Esri"
    'Change the title of the document.
    pDocInfo.DocumentTitle = "My Map Document"
    'Change the description of the document
    pDocInfo.Comments = "This is a demo."
    'Save the change
    pMapDoc.Save()
  • C# Sample
    Code:
    IMapDocument pMapDoc = new MapDocument();
    pMapDoc.Open("C:\\Untitled.mxd");
    IDocumentInfo2 pDocInfo = (IDocumentInfo2) pMapDoc;
    //Change the author of the document
    pDocInfo.Author = "Esri";
    //Change the title of the document.
    pDocInfo.DocumentTitle = "My Map Document";
    //Change the description of the document
    pDocInfo.Comments = "This is a demo.";
    //Save the change
    pMapDoc.Save();
  • JAVA Sample
    Code:
    pMapDoc.open("C:\\Untitled.mxd", "");
    IDocumentInfo2 pDocInfo = (IDocumentInfo2) pMapDoc ;
    pDocInfo.setAuthor("Esri");
    pDocInfo.setDocumentTitle ("My Map Document");
    //Change the description of the documentpDocInfo.setComments ("This is a demo.");
    //Save the change
    pMapDoc.save(false, false);
Article ID: 000013269
Software:
  • ArcObjects SDK for the Java Platform
  • ArcObjects SDK Microsoft NET Framework
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
