ERROR
When attempting to start additional GIS services or more instances of an existing GIS service in high isolation, the following error message may be returned by ArcGIS Server regarding the capacity of SOC machines:
"Server has no associated SOC machines or all SOC machines are at capacity."
ArcGIS Server log files may contain any of the following errors:
"Server object instance creation failed on all SOC machines."
"Document <path to map document> cannot be opened."
The number of ArcSOC.exe processes that can be started on a machine is limited by the amount of Available Physical Memory on the server. The amount of Available Physical Memory is not equal to the total memory since other processes, such as the operating system, also use memory. The amount of memory used by each process depends on the complexity of the services it handles.
ArcSOC.exe processes are considered user processes. By default, on a server with 4GB of RAM, the total of all user processes cannot exceed 2GB of RAM.
Windows 2003 Server and Windows 2000 operating systems include a control that adjusts how memory is allocated to system and user processes. This switch in the boot.ini file is called /3GB. For more information about how this switch allocates memory, see the Microsoft Knowledge Base article located in the Related Information section of this article.
If the server machine has more than 4GB of RAM, then the /3GB switch in the boot.ini file must be turned off to allow user processes to consume more than 3GB of memory.
Article ID:000009914
Get help from ArcGIS experts
Download the Esri Support App
