PROBLEM
Selections on Link Chart layers with default properties cause ArcGIS Pro (3.6.3) to crash
First Published: April 23, 2026
Last Published: April 23, 2026
In ArcGIS Pro 3.6.3, the application may unexpectedly crash when selecting data in a Link Chart layer that has default properties configured.
Steps That Trigger the Issue
  1. Configure default properties on a Link Chart layer.
  2. Add data from a Knowledge Graph to a new Link Chart.
  3. Select nodes or links in the Link Chart layer.
Solution or Workaround
If possible, roll back to ArcGIS Pro 3.6 Patch 2 (3.6.2).
Otherwise, close and open the new link chart before making a selection.
Resolution
This issue is scheduled to be fixed in the ArcGIS Pro 3.6.4 Patch 4. Once updated, Link Chart layers with default properties will no longer crash when data is selected.
Article ID: 000041407
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
