PROBLEM
Selected features from an ArcMap Service buffer are incorrect
ArcIMS Image Services allow the user to buffer and select features from the same layer.
If you buffer and select features of the same layer with an ArcMap Service you will get erroneous results or the request may cause the service to timeout.
Cause
ArcIMS Image Services create dynamic layers to draw the buffered features, the buffers, and features selected by the buffers.
ArcMap Services do not create dynamic layers. This inability may cause the results to be incorrect.
Solution or Workaround
There is no workaround for buffering and selecting features of the same layer.
ArcMap Services only allow for the buffering one layer and the selection of features of different layers.
Article ID:000005151
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
