HOW TO
It is possible to programmatically make a layer selected in the Table of Contents by using IContentsView::AddToSelectedItems. The result is the same as clicking the layer in the GUI; the layers will turn blue.
Code in the Project's ThisDocument code module will only run in the current map document. To store the code in all map documents open the Normal.mxt ThisDocument code module instead.
Code:
Sub SelectLayersInDisplayView()
' selects all of the layers in the first data frame in the toc's display view
Dim pMxDoc As IMxDocument
Set pMxDoc = ThisDocument
Dim ptoc As IContentsView
Set ptoc = pMxDoc.ContentsView(0) ' Display View
Dim pMaps As IMaps
Set pMaps = pMxDoc.Maps
Dim pMap As IMap
Dim i As Integer
Set pMap = pMaps.Item(0) ' first data frame
Dim pEnumLayer As IEnumLayer
Set pEnumLayer = pMap.Layers
Dim pLayer As ILayer
Set pLayer = pEnumLayer.Next
ptoc.RemoveFromSelectedItems ptoc.SelectedItem
Do While Not pLayer Is Nothing
ptoc.AddToSelectedItems pLayer
ptoc.Refresh pLayer
Loop
End Sub
Article ID:000007490
Get help from ArcGIS experts
Download the Esri Support App
