ERROR
When using a service name instead of the port number for -i parameter, the command 'sderaster' core dumps, on HP only, and the following intermittent error may occur:
"$SDEHOME/bin/sdetable -o create -t qa_rastab2 -d none -u vtest -p xx -s obiwan -i sde83_ora817
/usr/lib/dld.sl: Unresolved symbol: xdrmem_create (code) from /obi2/sde83/lib/libsde83.sl IOT trap (core dumped)"
Cause is under investigation.
Article ID:000006002
Get help from ArcGIS experts
Download the Esri Support App
